I mean that Laravel shows the php errors when they are even when debug mode is disabled. The showing errors isn’t good for security. I can’t understand why when the ‘debug’ => (bool) env(‘APP_DEBUG’, false), is disabled it continues showing errors.
Being a Laravel developer (since v4) I can almost guarantee you that the problem will be that you’ve not cleared/re-cached the Laravel config cache after making the changes…
You should login to the terminal (SSH into your HestiaCP account) and run these commands:
cd ~/web/{website}/public_html
php artisan config:cache
PS. If you regularly just upload changed files (and not the re-cached files) you might want to disable config caching altogether on the server… Let me know if you want to do that and if you need help with that - there will be a very small performance hit but may save you the hassle in future.
