Hello guys,
Anyone found a template for hosting in hestia a laravel framework?
Thank you inadvance
apache2+nginx or nginx only?
You might just be able to alter the domains root directory path in the control panel. I think laravel needs “public” added on the end or something (from memory)
I use the default config i guess apache+nginx
Then i would suggest to use either a custom template (Server management — Hestia Control Panel documentation) or set the custom docroot to public as @pluto already suggested.
