I can’t get Let’s encrypt to work on my NodeJS web domain bellerad.io .
I asked the Let’s encrypt community, : HestiaCP panel: Let’s encrypt finalize bad status 403 - Help - Let’s Encrypt Community Support (letsencrypt.org) . I was pointed out my server was rewriting an Url in lowercase. I tried to unroll these nginx parameters:
/etc/nginx,
/home/{my_user}/conf/web/bellerad.io
/home/{my_user}/hestiacp_nodejs_config/web/bellerad.io/
Unfortunately, I couldn’t find anything related to a rewrite. The only part that I thought related to my issue were the nginx.*.conf_letsencrypt file, but they only happen a string at the end of the .well-known/acme-challenge/ url, don’t they ?
Any clue ?
sahsanu
September 20, 2024, 2:13pm
2
Hi @BilboTheHobbyist ,
Show your nginx.conf.
cat /home/*/conf/web/bellerad.io/nginx.conf
Here you are (couldn’t find a way to upload it )
server {
listen XX.XX.XX.XX:80;
server_name bellerad.io www.bellerad.io ma.bellerad.io;
error_log /var/log/apache2/domains/bellerad.io.error.log error;
include /home/XXX/hestiacp_nodejs_config/web/bellerad.io/nodejs-app.conf;
location /error/ {
alias /home/XXX/web/bellerad.io/document_errors/;
include /home/XXX/hestiacp_nodejs_config/web/bellerad.io/nodejs-app-fallback.conf;
location ~ /\.ht {return 404;}
location ~ /\.svn/ {return 404;}
location ~ /\.git/ {return 404;}
location ~ /\.hg/ {return 404;}
location ~ /\.bzr/ {return 404;}
sahsanu
September 20, 2024, 2:37pm
4
It’s ok to copy and paste here but you didn’t paste all the contents of the file.
During copy-pasting, I missed the last }. Apart from that, I can’t see anything else I missed (cf. screen capture).
sahsanu
September 20, 2024, 2:55pm
6
Add this include before the first include (replace YourUser by the actual user):
include /home/YourUser/conf/web/bellerad.io/nginx.conf_*;
And then:
systemctl reload nginx
Once done you can test if you receive the right token instead of 404.
curl -ikL http://bellerad.io/.well-known/acme-challenge/TeSt
If this works, you should modify your template (tpl and stpl) to add the right includes and rebuild your site:
YourTemplate.tpl
YourTemplate.stpl
Brilliant ! I got me a certificate !
Thanks a lot , I’ll look into modifying my template, then.
