Hello everyone,
i have setup my first domain with mail service and everything is working. I did the same with a second domain. Domain gets SSL-Cert. But SSL-Generation for the mail service returns 400 error.
DNS Checker shows that the corresponding mail.* webmail.* subdomains are available worldwide.
Any guess how to fix that? Where can i find the log files?
thanks in advance girls and guys!
le400 has been answered so many times here in the forum, please use the search function and/or check our docs: SSL Certificates and Let's Encrypt — Hestia Control Panel documentation
I feel your pain with this problem and thank you for still answering. I followed your FAQ, but it didnt help.
Cloudflare proxy is enabled and SSL is set too strict.
no cloudfare but HTTP Strict Transport Security (HSTS) is enabled (works for first domain). i disabled it. still same problem
Nginx / Apache2 is not reloading / Issue with an template
what do you mean with reloading? i restartet the server and the services. no changes. templates are default
IPv6 is setup. Disable IPV6 in DNS
Wrong / Incorrect template.
https://letsdebug.net/ tells me everything is fine.
DNS on Netcup:
A @
CNAME mail domain.tld.
CNAME webmail domain.tld.
CNAME www domain.tld.
"type": "http-01",
"status": "invalid",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://webmail.XXX.de/.well-known/acme-challenge/... [152.XXX.XXX.191]: \"\u003c!DOCTYPE html\u003e\\n\u003chtml lang=\\\"en\\\"\u003e\\n\u003chead\u003e\\n\u003cmeta charset=\\\"UTF-8\\\"\u003e\\n\u003cmeta name=\\\"viewport\\\" content=\\\"width=device-width, initial-scale=\"",
"status": 403
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/...",
"token": "...",
"validationRecord": [
"url": "http://webmail.XXX.de/.well-known/acme-challenge/...",
"hostname": "webmail.XXX.de",
"port": "80",
"addressesResolved": [
"152.XXX.XXX.191"
"addressUsed": "152.XXX.XXX.191"
"validated": "2022-03-02T14:50:53Z"
eris
March 2, 2022, 3:38pm
4
If you have accidentally disabled it:
v-add-sys-webmail user domain.com roundcube or v-add-sys-webmail user domain.com rainloop will restore it in CLI
We will release an update shortly…
ok. i saw this too i just wait for your hotfix and will go on later.
@Raphael Now i tried it again. Everything worked flawlessly after newest updates thanks!
