Let's Encrypt SSL on specific port(s) & for docker ports
Host: example1.domain.tld / example2.domain.tld / dockercotainer.domain.tld
Port: 81 & 83 / 2978 & 2283 / docker_port1 & 2
So for my host which is under a separate port, the SSL got generated via /usr/local/bin/hestia/v-add-letsencrypt-host, however, I am not sure how I can get the rest done. I searched long, and being non-technical, I could not get this done for any of my ports. :frowning:
Any help will be appreciated please.
My current sys-config, if that is required:
**/usr/local/hestia/bin# v-list-sys-config**
Web Server:                       apache2:8080 (www-data)
SSL Support:                      mod_ssl:8443
Web Backend:                      php-fpm
Proxy Server:                     nginx:80
Proxy SSL:                        nginx:443
Version:                          1.8.12
Release Branch:                   release
You can’t Lets encrypt only works on port 80 and 443
That is why you can use Hestia to create a template to forward traffic to your docker host
Thanks @eris for the quick response. It is not just for docker, but also for other ports. Example: 81, 83, 2897, etc., etc.,
Also, how can I use hestia to create this template? Apologies, I am fairly new to these stuffs, and love hestia for being almost very good for newbies like me.
Edit: I can see it here - Web Templates and FastCGI/Proxy Cache | Hestia Control Panel, but as I mentioned, I am not sure.
I did not get the above docker done, but I was finally able to get forgejo (port 3000) (specific port) redirect to https with let’s encrypt ssl.
I created a normal subdomain at normal 80/443 ports with LE SSL generated.
Then in the forgejo app.ini (/etc/forgejo/app.in) file, added this under [server]
[server]
ENABLE_ACME = enable
HTTPS_PORT = 3000 ssl
ROOT_URL = https://git.domain.tld
Then under nginx.conf ($HESTIADATA\conf\web\git.domain.tld\nginx.conf) I added
location / {
    client_max_body_size 4096M;
    proxy_pass http://localhost:3000;
    proxy_set_header Connection $http_connection;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Host $host;
Then under apache2.conf ($HESTIADATA\conf\web\git.domain.tld\apache2.conf) I added
ProxyPreserveHost On
ProxyRequests off
AllowEncodedSlashes NoDecode
ProxyPass / http://localhost:3000/ nocanon
Then under apache2.ssl.conf ($HESTIADATA\conf\web\git.domain.tld\apache2.ssl.conf) I added
< VirtualHost git.domain.tld:8443 https >
ProxyRequests off
I also enabled the following to ensure the proxy works:
a2enmod proxy
a2enmod proxy_http
a2enmod proxy_balancer
a2enmod proxy_wstunnel
systemctl restart apache2
systemctl restart nginx
systemctl start forgejo.service
I got the help from these:
APache SSL Long Record Error
Let’s Encrypt SSL Certificate
Gitea Reverse Proxy - Apache HTTPD
Gitea Reverse Proxy - General Conf
Gitea Reverse Proxy - NGINX
