Lets Encrypt validation fails - Invalid response
I have the same error as discussed many times, e.g. in forum.hestiacp com/t/unable-to-get-ssl-for-hestia-cp/8248/10
Situation
I tried everything I found to no avail, the issue persisted throughout the last weeks, through restarts of the VM and nginx, with no apparent errors.
It happens for all new domains and some current ones, but even within a single user there are domains that error out and some that work.
There is no Cloudflare proxying.
The issue occurs both from CLI and Web UI, e.g.:
v-add-letsencrypt-domain owner DOMAIN
Error: Let's Encrypt validation status 400 (DOMAIN). Details: 403:"HESTIA_IP: Invalid response from http://DOMAIN/.well-known/acme-challenge/QsqBVN6pyV9QeFohNmJmzKRyI4z3dYW_XbPhRivb1UI: 404"
Debugging
I plowed through:
github com/hestiacp/hestiacp/issues/1509
forum.hestiacp com/t/lets-encrypt-ssl-error-error-lets-encrypt-validation-status-400-domain-com-details-403-my-ip-invalid-response/7651>
According to https://docs.hestiacp.com/admin_docs/web/ssl_certificates.html#error-let-s-encrypt-validation-status-400 I checked /var/log/hestia/LE-owner-DOMAIN.log which contained
details: Unable to update challenge :: authorization must be pending
letsdebug reports no problems
According to https://docs.hestiacp.com/admin_docs/settings.html I enabled DEBUG_MODE and checked the logs, but did not get anything out of theat, see below.
Logs
This is an extract from lnav /var/log/hestia, maybe something unusual here:
I am a little bit confused about all the failed added records and domains, because we did not add any except the one with letsencrypt.
Check /var/log/hestia/LE-user-domain.log
It should contain more info
I did check it, as mentioned above. Here is the full one with private info redacted:
Date Time: 2022-12-20 11:48:49
WEB_SYSTEM: apache2
PROXY_SYSTEM: nginx
user: owner
domain: DOMAIN
- aliases:
- proto: http-01
- wildcard:
==[Step 1]==
- status: 200
- nonce: F977DKtq9LE411CKahC9RbBzC9yPOfODmzc_ZQiivLpS21o
- answer: HTTP/2 200
server: nginx
date: Tue, 20 Dec 2022 10:48:50 GMT
content-type: application/json
content-length: 659
replay-nonce: F977DKtq9LE411CKahC9RbBzC9yPOfODmzc_ZQiivLpS21o
x-frame-options: DENY
strict-transport-security: max-age=604800
==[API call]==
exit status: 0
==[Step 2]==
- status: 201
- nonce: A5FEsTHUVC3yKB2fYuFmZAlJYnGawazYEuJbPtbn2ocsmv4
- authz: https://acme-v02.api.letsencrypt.org/acme/authz-v3/188507753607
- finalize: https://acme-v02.api.letsencrypt.org/acme/finalize/515162167/153847387397
- payload: {"identifiers":[{"type":"dns","value":"DOMAIN"}]}
- answer: HTTP/2 201
server: nginx
date: Tue, 20 Dec 2022 10:48:51 GMT
content-length: 334
boulder-requester: 515162167
link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index"
location: https://acme-v02.api.letsencrypt.org/acme/order/515162167/153847387397
replay-nonce: A5FEsTHUVC3yKB2fYuFmZAlJYnGawazYEuJbPtbn2ocsmv4
  "status": "pending",
  "expires": "2022-12-27T10:48:51Z",
  "identifiers": [
      "type": "dns",
      "value": "DOMAIN"
  "authorizations": [
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/188507753607"
  "finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/515162167/153847387
397"
==[API call]==
exit status: 0
==[Step 3]==
- status: 200
- nonce: 371CmL9LQe1OR5E2m1mOCaJPygED74-6xYCOQ_KETgV78mE
- url: https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/upM-qg
- token: REDACTED1NxYMOnsOclTOS3ecLe5Uhh4KTErVePnW3o
server: nginx
content-length: 793
replay-nonce: 371CmL9LQe1OR5E2m1mOCaJPygED74-6xYCOQ_KETgV78mE
  "identifier": {
    "type": "dns",
    "value": "DOMAIN"
  "challenges": [
      "type": "http-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/upM-qg"
      "token": "REDACTED1NxYMOnsOclTOS3ecLe5Uhh4KTErVePnW3o"
      "type": "dns-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/TGH3gA"
      "type": "tls-alpn-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/Towuwg"
==[API call]==
exit status: 0
==[Step 5]==
- status: 200
- nonce: F977Df_98vqDY6D4OUMy3At4rwbzcBHfHf7amkTzBTfQXAw
- validation: pending
- details:
server: nginx
date: Tue, 20 Dec 2022 10:49:01 GMT
content-length: 187
link: <https://acme-v02.api.letsencrypt.org/acme/authz-v3/188507753607>;rel="up"
location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/upM-qg
replay-nonce: F977Df_98vqDY6D4OUMy3At4rwbzcBHfHf7amkTzBTfQXAw
  "type": "http-01",
  "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/188507753607/upM-qg",
==[API call]==
exit status: 0
==[Step 5]==
- status: 400
- nonce: 2712Jw91S5_d1mfpPQwhvdc92QleimES2g8Tk6ozTJyZfbY
- validation:
- details: Unable to update challenge :: authorization must be pending
- answer: HTTP/2 400
server: nginx
date: Tue, 20 Dec 2022 10:49:05 GMT
content-length: 144
replay-nonce: 2712Jw91S5_d1mfpPQwhvdc92QleimES2g8Tk6ozTJyZfbY
  "type": "urn:ietf:params:acme:error:malformed",
  "detail": "Unable to update challenge :: authorization must be pending",
  "status": 400
==[Debug information Step 5]==
  "type": "http-01",
  "status": "invalid",
  "error": {
    "type": "urn:ietf:params:acme:error:unauthorized",
    "detail": "IP: Invalid response from http://DOMAIN/.well-known/ac
me-challenge/REDACTED1NxYMOnsOclTOS3ecLe5Uhh4KTErVePnW3o: 404",
    "status": 403
  "token": "REDACTED1NxYMOnsOclTOS3ecLe5Uhh4KTErVePnW3o",
  "validationRecord": [
      "url": "http://DOMAIN/.well-known/acme-challenge/REDACTED1NxYMOnsOclTOS3ecLe
5Uhh4KTErVePnW3o",
      "hostname": "DOMAIN",
      "port": "80",
      "addressesResolved": [
        "IP"
      "addressUsed": "IP"
  "validated": "2022-12-20T10:49:01Z"
==[Abort Step 5]==
=> Wrong status
If you visits this page you should see a string but a 403 page got served without a domain name I can’t do a lot on debugging… You can try to restart nginx…
I did restart nginx and the whole machine, no luck.
Visiting that URL does produce a 403.
is your website redirecting? probaly custom htaccess?
no, nothing customised, this happens for fresh domains as well!
Have you tested with Let’s Debug?
yes I did, as written above, reported no issues either
With a domain I really can’t do any thing.
We checked it in private chat, this is the temporary fix provided by @eris
Replace:
With
$BIN/v-restart-proxy yes
And
With
$BIN/v-restart-web yes
And then run v-add-letsencrypt-domain user domain.com
