I have a problem with the SSL and I hope someone can help here.
I noticed that the site certificate did not renew. I tried to manually renew it (remove SSL then add again) via the UI but all I got is an error code 3 just as I am trying to remove the SSL.
Has anyone happened ever experienced this before? I don’t even know where to look for clues.
Thanks in advance!
Regards,
Joseph
P.S.
Hestia version is v1.4.3
OS is the latest Ubuntu server server
It seems that although you have DNS entries set up on your server, that the domain is actually using nameservers at ns2.io-servers.com and ns1.io-servers.com
So that’s where you need to set up your DNS.
OR. change the nameservers to point to your current machine
Your right, the name servers being used is external as it’s really hosted externally. The site is the one hosted in hestia. I can also guarantee that the DNS is fully declared and available in our hosting provider. It’s just that the letsencrypt renewals are not working on hestia and it;s just for this domain. Aside from the error code 3, I don’t have any other errors to work with.
