Setting domain.tld:8083/edit/server/ Backup > Local Backup to “no” seems to have no impact i.e. local backup in the quantity specified in the packaged is created and not deleted.
My goal is for hestia to generate and store 3-7 days of remote b2 backups and store none locally. My assumption would be: Set quantity in package. Set remote backups to b2 and set local backup to “no” And hestia would keep backups of that quantity on b2 and store no local backups.
Is there a way to do this? Am I missing something?
Thanks @eris Like I said this is not the case and this is not working as expected. Local backups are being created and stored daily. Can you help me troubleshoot?
I had some time to look into this. And this is not a bug, but rather my mis-interpretation of the hestia backup gui. I expected only local backups to show up there and be available for download. but I see that the gui specifies the types i.e. rclone,local if local=yes and downloads the local copy. This was also my error in mis-reading the dates of the old files in /backups directory. Everything is working as expected now that I understand how I was mis-understanding how things worked.
Thanks for your help @eris and heads up that direct hestia b2 functionality will be deprecated. I switched to rclone.
