Log in to phpmyadmin via the admin panel in 1 click
Good afternoon developers, I remember this item was in trouble that year, well, it was postponed for release and due to difficulties in implementation, will this feature appear in future updates or should it not be expected?. I would also like to know if there will be php compositor support from the panel
If you are talking about phpMyAdmin Single Sign On, then it works fine for me. I have enabled it at Hestia UI Settings > Databases and made sure I followed the docs here PhpMyAdmin Single Sign On — Hestia Control Panel documentation
I meant when you click on the database, it immediately enters it as authorized
Judging by the instructions, I select the API, specify the IP address of my server, and I get Page Not Found when I click on the database entry
Make sure you access Hestia via hostname.domain.com and not over ip
Page Not Found
Tried to disable and display ip, tried to exit via ip+port
Or do you need to enter a password here?
you’ve a proxy redirect to 8083 there, this can’t work because you cant reach phpmyadmin on port 8083. Also do not post hostnames or even full links with one click login creds into the wild…
In that case
and
or:
and
The have the correct rules to allow for phpmyadmin to remain accessble
According to the configs, everything goes as above, where else can you dig to solve the problem?
Check your error logs of the domain
http://joxi.ru/KAgVW7qU5a5382
176.124.134.234 - - [14/Mar/2022:22:22:51 +0500] “GET /phpmyadmin//hestia-sso.php?database=admin&user=admin&exp=164754184&hestia_token=$2y$10$/.td8fwbKnWYXZun5IlrckQt8PQytjMiccFau HTTP/2.0” 404 1430 “cp.glonin.kz - login - Панель управления Hestia” “Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.51 Safari/537.36”
the strange thing is that when you click on the link https://my.domain.kz/phpmyadmin/hestia-sso.php we get 404
although there is a physical file
https://my.domain.kz/phpmyadmin/index.php is served from this directory normally
Hi @eris,
I just installed HestiaCP on a fresh os installation, on ubuntu 24.04 with NGINX.
I’m tryng to enable phpmyadmin SSO but it shows me an error:
… but I have a DB server on localhost, I can connect to it with the standard db user created on web domain…
