Login fails after ROUNDCUBE update
Thank you very much its working now. turned false to true :pray: :+1:
Yes …
For the sake of completeness…
Ubuntu 18.04.06:
$config[‘auto_create_user’] = false;
and
Debian 9
Best regards
Tom
It should changed to true…
I will test it. So far everything is working.
It is only not working if you create a new account and try to login for the first time via Roundcube.
Then I still have a few changes to make :slight_smile:
please, where is the path in Debian, if you now? i did not found config.inc.php
/etc/roundcube/config.inc.php
hi @eris
you’ve told me else where to reinstall hestia
will i need to apply the steps commented here, or the reinstall will do it all right?
Reinstall should fix it
