the system keeps login me out , it happens frequently even in a fresh installed panel
the login and password are correct
Does your browser have cookies enabled?
yes, it is in use
Check in /usr/local/hestia/conf/hestia.conf INACTIVE_SESSION_TIMEOUT=‘60’ it should be 60
yes it is set to 60, still have the same problem , i changed browser but still same issue
Check /var/log/hestia/auth.log if the login it self is successfull
2021-08-23 00:14:39 admin .... successfully logged in
2021-08-23 00:17:25 admin .... successfully logged in
2021-08-23 00:36:48 admin .... successfully logged in
2021-08-23 00:41:52 admin .... successfully logged in
yes all the logins are successful , when i click on something or i save something , it log me out
Are you connecting via https?
/usr/local/hestia/data/sessions write able for admin user.
yes but the certificate is not trusted
the /sessions folder is 770, ( read/write/execute) for owner , and ( read/write/execute) for group
It should be fine. I have no idea any more with out some additional testing. If you want you can DM me the ssh details and I will have a quick look.
i sent u the details
