sahsanu
November 7, 2024, 10:56pm
2
You can install it on your own:
sudo -i
pip install limited-shell --break-system-packages
curl -fsSL "https://raw.githubusercontent.com/ghantoos/lshell/refs/heads/master/etc/lshell.conf" -o /etc/lshell.conf
echo '/usr/local/bin/lshell' >> /etc/shells
Now you can assign lshell to any user via Web UI or from command line:
v-change-user-shell YourUser lshell
Yes, I already did that. After which I wrote on this forum. It would just be nice if it was by default after installation.
linkp
November 8, 2024, 12:45am
4
It is far better to not force things like that on everyone. If you want it, you can add it to your server. There is no need to make everyone install something that most have no use for.
v-add-user-ssh-jail tests3
invalid shell, /srv/jail/tests3/usr/local/bin/lshell does not exist
Hello. After running this command I get an error. It doesn’t matter what shell is installed, bash, sh, lshell, etc. How can I fix it?
