On a fresh install on Ubuntu 22.04 I have multiple domains setup each serving a different website and has its respective mail server. The control panel is also on a domain: cphestia@domain(dot)com
I am having issues with receiving mail from certain addresses (not all). Emails for certain domains are bouncing and the senders are receiving the following messages in their mailboxes:
For example say the the following address test@senderdomain(dot)com sends me an email to me@domain2(dot)com, if I run:
sudo exim4 -d -bvs
I get the following:
Exim version 4.95 uid=0 gid=0 pid=456037 D=f7715cfd
Support for: crypteq iconv() IPv6 PAM Perl Expand_dlfunc GnuTLS TLS_resume move_frozen_messages Content_Scanning DANE DKIM DNSSEC Event I18N OCSP PIPE_CONNECT PRDR PROXY Experimental_Queue_Ramp SOCKS SRS TCP_Fast_Open
Lookups (built-in): lsearch wildlsearch nwildlsearch iplsearch cdb dbm dbmjz dbmnz dnsdb dsearch ldap ldapdn ldapm mysql nis nis0 passwd pgsql sqlite
Authenticators: cram_md5 cyrus_sasl dovecot external plaintext spa tls
Routers: accept dnslookup ipliteral iplookup manualroute queryprogram redirect
Transports: appendfile/maildir/mailstore/mbx autoreply lmtp pipe smtp
Malware: f-protd f-prot6d drweb fsecure sophie clamd avast sock cmdline
Fixed never_users: 0
Configure owner: 0:0
Size of off_t: 8
Compiler: GCC [11.4.0]
Library version: Glibc: Compile: 2.35
Runtime: 2.35
Library version: BDB: Compile: Berkeley DB 5.3.28: (September 9, 2013)
Runtime: Berkeley DB 5.3.28: (September 9, 2013)
Library version: GnuTLS: Compile: 3.7.3
Runtime: 3.7.3
Library version: IDN2: Compile: 2.3.2
Runtime: 2.3.2
Library version: Stringprep: Compile: 1.38
Runtime: 1.38
Library version: Cyrus SASL: Compile: 2.1.27
Runtime: 2.1.27 [Cyrus SASL]
Library version: PCRE: Compile: 8.39
Runtime: 8.45 2021-06-15
Total 20 lookups
Library version: MySQL: Compile: 80035 8.0.35 [mysqld-8.0]
Runtime: 80036 8.0.36
Library version: SQLite: Compile: 3.37.2
Runtime: 3.37.2
WHITELIST_D_MACROS: "OUTGOING"
TRUSTED_CONFIG_LIST: "/etc/exim4/trusted_configs"
changed uid/gid: forcing real = effective
auxiliary group list: <none>
seeking password data for user "root": cache not available
getpwnam() succeeded uid=0 gid=0
seeking password data for user "Debian-exim": cache not available
getpwnam() succeeded uid=116 gid=122
configuration file is /var/lib/exim4/config.autogenerated
log selectors = 00000ffc 64205022 0000009c
trusted user
admin user
changed uid/gid: privilege not needed
uid=116 gid=122 pid=456037
auxiliary group list: 8 122
originator: uid=0 gid=0 login=root name=root
sender senderdomain = [email protected](dot)com
Verifying: uid=116 gid=122 euid=116 egid=122
Verifying test@senderdomain(dot)com
Considering test@senderdomain(dot)com
routing test@senderdomain(dot)com
--------> send_via_unauthenticated_smtp_relay router <--------
local_part=samb domain=senderdomain(dot)com
send_via_unauthenticated_smtp_relay router skipped: verify 1 0 0
--------> send_via_smtp_relay router <--------
send_via_smtp_relay router skipped: verify 1 0 0
--------> dnslookup router <--------
checking domains
search_open: dsearch "/etc/exim4/domains/"
search_find: file="/etc/exim4/domains/"
key="senderdomain(dot)com" partial=-1 affix=NULL starflags=0 opts=NULL
LRU list:
5/etc/exim4/domains/
End
internal_search_find: file="/etc/exim4/domains/"
type=dsearch key="senderdomain(dot)com" opts=NULL
file lookup required for senderdomain(dot)com
in /etc/exim4/domains/
creating new cache entry
lookup yielded: senderdomain(dot)com
senderdomain(dot)com in "dsearch;/etc/exim4/domains/"? yes (matched "dsearch;/etc/exim4/domains/")
data from lookup saved for cache for +local_domains: key 'senderdomain(dot)com' value 'senderdomain(dot)com'
senderdomain(dot)com in "!+local_domains"? no (matched "!+local_domains")
dnslookup router skipped: domains mismatch
--------> userforward router <--------
userforward router skipped: verify 1 0 0
--------> procmail router <--------
procmail router skipped: verify 1 0 0
--------> autoreplay router <--------
checking require_files
cached open
LRU list:
End
cached data used for lookup of senderdomain(dot)com
file check: /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
expanded file: /etc/exim4/domains/senderdomain(dot)com/autoreply.samb.msg
stat() yielded -1
errno = 2
autoreplay router skipped: file check
--------> aliases router <--------
file check: /etc/exim4/domains/$domain/aliases
expanded file: /etc/exim4/domains/senderdomain(dot)com/aliases
stat() yielded 0
calling aliases router
rda_interpret (string): '${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}'
cached open
LRU list:
End
search_open: lsearch "/etc/exim4/domains/senderdomain(dot)com/aliases"
search_find: file="/etc/exim4/domains/senderdomain(dot)com/aliases"
key="test@senderdomain(dot)com" partial=-1 affix=NULL starflags=0 opts=NULL
LRU list:
:/etc/exim4/domains/senderdomain(dot)com/aliases
End
internal_search_find: file="/etc/exim4/domains/senderdomain(dot)com/aliases"
type=lsearch key="test@senderdomain(dot)com" opts=NULL
file lookup required for test@senderdomain(dot)com
in /etc/exim4/domains/senderdomain(dot)com/aliases
lookup failed
expanded: ''
file is not a filter file
parse_forward_list:
aliases router declined for test@senderdomain(dot)com
--------> localuser_fwd_only router <--------
checking "condition" "${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/e"...
cached open
LRU list:
End
search_open: lsearch "/etc/exim4/domains/senderdomain(dot)com/fwd_only"
search_find: file="/etc/exim4/domains/senderdomain(dot)com/fwd_only"
key="samb" partial=-1 affix=NULL starflags=0 opts=NULL
LRU list:
:/etc/exim4/domains/senderdomain(dot)com/fwd_only
End
internal_search_find: file="/etc/exim4/domains/senderdomain(dot)com/fwd_only"
type=lsearch key="samb" opts=NULL
file lookup required for samb
in /etc/exim4/domains/senderdomain(dot)com/fwd_only
lookup failed
localuser_fwd_only router skipped: condition failure
--------> localuser_spam router <--------
checking "condition" "${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_par"...
cached open
LRU list:
End
search_open: lsearch "/etc/exim4/domains/senderdomain(dot)com/passwd"
search_find: file="/etc/exim4/domains/senderdomain(dot)com/passwd"
LRU list:
:/etc/exim4/domains/senderdomain(dot)com/passwd
End
internal_search_find: file="/etc/exim4/domains/senderdomain(dot)com/passwd"
in /etc/exim4/domains/senderdomain(dot)com/passwd
lookup failed
localuser_spam router skipped: condition failure
--------> localuser router <--------
checking "condition" "${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/ex"...
cached open
LRU list:
End
cached open
LRU list:
End
cached data used for lookup of samb
lookup failed
localuser router skipped: condition failure
--------> catchall router <--------
stat() yielded 0
checking "condition" "${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch"...
cached open
LRU list:
End
cached open
LRU list:
End
cached data used for lookup of test@senderdomain(dot)com
lookup failed
calling catchall router
rda_interpret (string): '${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}'
cached open
LRU list:
End
cached open
key="*@senderdomain(dot)com" partial=-1 affix=NULL starflags=0 opts=NULL
LRU list:
End
type=lsearch key="*@senderdomain(dot)com" opts=NULL
file lookup required for *@senderdomain(dot)com
lookup failed
expanded: ''
parse_forward_list:
catchall router declined for test@senderdomain(dot)com
--------> terminate_alias router <--------
cached open
LRU list:
End
cached open
LRU list:
End
lookup failed
terminate_alias router skipped: condition failure
no more routers
test@senderdomain(dot)com failed to verify: Unrouteable senderdomain
search_tidyup called
>>>>>>>>>>>>>>>> Exim pid=456037 (fresh-exec) terminating with rc=2 >>>>>>>>>>>>>>>>
The weird thing is that I can normally receive emails on that same address from gmail and other domains.
I’ve been read many posts on similar topics but none of them were the same case (but I tried their solutions anyway).
I would appreciate any input on the issue.
PS: if there’s any additional info/logs that would provide more insight please let me know to update the post.
Thank you
