Mail not received anymore
After the update v1.8.1. I can still send mail but are unable to receive them.
How can I fix that ?
I also noticed this in the notification section :
  • IMPORTANT: Manual Action Required
To enable the ‘Enhanced and Optimized TLS’ feature, we must update the NGINX configuration file at /etc/nginx/nginx.conf.
But for unknown reason or you edited it, may not be fully apply all the changes in this upgrade.
Please follow the default configuration file to sync it:
/usr/local/hestia/install/deb/nginx/nginx.conf
Backed up configuration file:
/root/hst_backups/120720230141/conf/nginx/nginx.conf
Visit PR #3555 on GitHub to learn more.
01:41:07 2023-07-12
Please help me fix the issue
Check /var/log/exim4/mainlog and check for any error messages…
logs saying my IP was banned at zen.spamhaus.org . However when I went to check at https://check.spamhaus.org/ its not listed. IP and all associated domain names are clear.
I’ve edited /etc/exim/dnsbl.conf to remove spamhaus and restarted exim, so that is the quick fix.
Long fix here :
https://hestiacp.com/docs/server-administration/email
