Check the contents if you see some thing…
Any logs even better send a email from on other email adress and check the server logs on that server and see what happens.
2022-12-08 00:03:56 no host name found for IP address 104.153.76.11103.153.76.11
2022-12-08 00:03:58 dovecot_login authenticator failed for (User) [103.153.76.11]: 535 Incorrect authentication data (set_id=support)
2022-12-08 00:04:03 Start queue run: pid=375566
2022-12-08 00:04:03 1p2LTS-000iiW-Jp Message is frozen
2022-12-08 00:04:03 1p2hwz-0019Ml-J4 Message is frozen
2022-12-08 00:06:14 1p34KY-001ZdW-31 H=hestia.example.com [33.77.207.198]: SMTP timeout after initial connection: Connection timed out
2022-12-08 00:06:14 1p34KY-001ZdW-31 == [email protected] R=dnslookup T=remote_smtp defer (110): Connection timed out H=hestia.example.com [35.77.207.197]: >
2022-12-08 00:06:14 1p34KY-001ZdW-31 ** [email protected]: retry timeout exceeded
2022-12-08 00:06:14 1p34QY-001Zll-Jr <= <> R=1p34KY-001ZdW-31 U=Debian-exim P=local S=2224
2022-12-08 00:06:14 1p34KY-001ZdW-31 Completed
2022-12-08 00:06:14 1p34QY-001Zll-Jr ** [email protected] R=dnslookup T=remote_smtp: all hosts for ‘hestia.example.com’ have been failing for a long time (a>
2022-12-08 00:06:14 1p34QY-001Zll-Jr Frozen (delivery error message)
2022-12-08 00:06:14 End queue run: pid=375566
2022-12-08 00:09:41 no host name found for IP address 104.153.76.11
2022-12-08 00:09:44 dovecot_login authenticator failed for (User) [104.153.76.11]: 535 Incorrect authentication data (set_id=oracle)
2022-12-08 00:15:26 no host name found for IP address 104.153.76.11
2022-12-08 00:15:28 dovecot_login authenticator failed for (User) [104.153.76.11]: 535 Incorrect authentication data (set_id=sybase)
2022-12-08 00:19:06 H=mail-ed1-f46.google.com [209.85.208.46] X=TLS1.3:ECDHE_X25519__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no SNI=mail.example.com F=
2022-12-08 00:21:13 no host name found for IP address 104.153.76.11
2022-12-08 00:21:15 dovecot_login authenticator failed for (User) [104.153.76.11]: 535 Incorrect authentication data (set_id=informix)
2022-12-08 00:27:00 no host name found for IP address 104.153.76.11
2022-12-08 00:27:03 dovecot_login authenticator failed for (User) [104.153.76.11]: 535 Incorrect authentication data (set_id=oracle8)
2022-12-08 00:29:05 no host name found for IP address 176.111.173.54
2022-12-08 00:29:08 dovecot_login authenticator failed for (User) [176.111.173.54]: 535 Incorrect authentication data ([email protected]\001r\001n)
2022-12-08 00:32:48 no host name found for IP address 104.153.76.11
2022-12-08 00:32:50 dovecot_login authenticator failed for (User) [104.153.76.11]: 535 Incorrect authentication data (set_id=server)
2022-12-08 00:34:03 Start queue run: pid=377818
2022-12-08 00:34:03 1p2LTS-000iiW-Jp Unfrozen by errmsg timer
2022-12-08 00:34:03 1p2LTS-000iiW-Jp ** [email protected] R=dnslookup T=remote_smtp: all hosts for ‘hestia.example.com’ have been failing for a long time (a>
2022-12-08 00:34:03 1p2LTS-000iiW-Jp [email protected]: error ignored
2022-12-08 00:34:03 1p2LTS-000iiW-Jp Completed
2022-12-08 00:34:03 1p2hwz-0019Ml-J4 Message is frozen
2022-12-08 00:34:03 1p34QY-001Zll-Jr Message is frozen
It’s surprising to me in cyberpanel can receive mail but cannot send mail. Hesticap can send email but cannot receive email.
Without a domain I can’t really debug anything…
Thanks. Appreciate your help.
I have installed the full website again fresh. Maybe a few records left in Namecheap. If any other information needed please tell me. Got a sendgrid account. smtp relay may be possible.
solutionclip.xyz
