Manually ejected cron tasks
Hello!
would there be an option so that the cron tasks could run it manually if wanted and not wait for the automation to do it?
You can run the same command from a prompt manually as you can automatically from a cron job, if that’s what you are asking. Just use ssh to connect to your VPS. You won’t be using the web UI to manually trigger cron jobs if that is what you are wondering.
