Mariadb broken, please help
A few days ago, my website usually get errors then I thought it was because of the Redis server because I upgraded Redis to the latest version two days ago. Then I download the 6.x version and do downgrade Redis just like I upgrade it.
That seems like a stupid downgrade.
Today, all my websites are down and MySQL stopped working because the disk is FULL.
System log files and email log files increased to more than 100GB. But I didn’t know the disk is full immediately, I tried to do something (I don’t remember what I did) with Redis before that.
I tried to remove and reinstall MariaDB server but every time I did the server will try to install Redis
sudo apt-get install mariadb-server
Reading package lists... Done
Building dependency tree... Done
mariadb-server is already the newest version (1:10.11.2+maria~deb11).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up redis-server (5:6.0.16-1+deb11u2) ...
Job for redis-server.service failed because the control process exited with error code.
See "systemctl status redis-server.service" and "journalctl -xe" for details.
find: ‘/etc/redis’: No such file or directory
dpkg: error processing package redis-server (--configure):
 installed redis-server package post-installation script subprocess returned error exit status 1
 redis-server
I completely removed Redis but still can’t install the MariaDB server.
Could you please give me some hints?
It’s urgent because the websites are still down.
Thank you for your time.
systemctl status mariadb.service
● mariadb.service - MariaDB 10.11.2 database server
     Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
    Drop-In: /etc/systemd/system/mariadb.service.d
             └─migrated-from-my.cnf-settings.conf
     Active: failed (Result: exit-code) since Sat 2023-05-06 15:38:15 UTC; 10s ago
       Docs: man:mariadbd(8)
             https://mariadb.com/kb/en/library/systemd/
    Process: 655354 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
    Process: 655355 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 655357 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && syste>
    Process: 655386 ExecStart=/usr/sbin/mariadbd $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
   Main PID: 655386 (code=exited, status=1/FAILURE)
     Status: "MariaDB server is down"
        CPU: 100ms
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [Note] InnoDB: Starting shutdown...
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [ERROR] Plugin 'InnoDB' init function returned error.
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [Note] Plugin 'FEEDBACK' is disabled.
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [ERROR] Unknown/unsupported storage engine: InnoDB
May 06 15:38:15 server.example.com mariadbd[655386]: 2023-05-06 15:38:15 0 [ERROR] Aborting
May 06 15:38:15 server.example.com systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
May 06 15:38:15 server.example.com systemd[1]: mariadb.service: Failed with result 'exit-code'.
May 06 15:38:15 server.example.com systemd[1]: Failed to start MariaDB 10.11.2 database server.
I fixed it myself
