my clients site is struggling with DDOS attacks. As of now their setup looks like this:
Visitor → Cloudflare → Sucuri → FIrewal 7G WAF on HestiaCP → Server
Looks decent for me, but attackers still manage to take down this server. They’re crashing mariadb, and we have to reboot entire server because systemctl restart mariadb is not starting it back.
I’ll put my config and logs below. Maybe someone can offer paid help?
tail -50 /var/log/mysql/error.log
https://pastebin.com/thTcQHyp
Example of erros in site.errors.log
https://pastebin.com/ehGZrQ48
cat my.cnf
[client]
port=3306
socket=/run/mysqld/mysqld.sock
default-character-set=utf8mb4
[mysql]
[mysqld_safe]
[mysqld]
user=mysql
pid-file=/run/mysqld/mysqld.pid
port=3306
basedir=/usr
datadir=/var/lib/mysql
tmpdir=/tmp
lc-messages-dir=/usr/share/mysql
general_log=OFF
log_error=/var/log/mysql/error.log
collation-server = utf8mb4_unicode_520_ci
init-connect='SET NAMES utf8mb4'
character-set-server = utf8mb4
symbolic-links=0
local-infile=0
skip-external-locking
key_buffer_size = 48M
max_allowed_packet = 500M
table_open_cache = 256
sort_buffer_size = 1M
read_buffer_size = 1M
read_rnd_buffer_size = 4M
myisam_sort_buffer_size = 64M
thread_cache_size = 8
query_cache_size= 64M
innodb_buffer_pool_size = 20G
innodb_log_file_size = 3G
#innodb_use_native_aio = 0
innodb_file_per_table
max_connections=8000
max_user_connections=0
wait_timeout=150
interactive_timeout=60
long_query_time=10
!includedir /etc/mysql/conf.d/
!includedir /etc/mysql/mariadb.conf.d/
!includedir /etc/mysql/releem.conf.d
perl mysqltuner
Hope someone can point me in right direction.
EDIT:
PHP-8_3.tpl
root@hello:/usr/local/hestia/data/templates/web/php-fpm# cat tuned-PHP-8_3.tpl
; origin-src: deb/php-fpm/multiphp.tpl
;# Default Web Domain Template #
;# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
;# https://hestiacp.com/docs/server-administration/web-templates.html #
[%domain%]
listen = /run/php/php%backend_version%-fpm-%domain%.sock
listen.owner = %user%
listen.group = www-data
listen.mode = 0660
user = %user%
group = %user%
pm = ondemand
pm.max_children = 600
pm.start_servers = 100
pm.max_requests = 1000
slowlog = /var/log/php8.3-fpm.log.slow
request_slowlog_timeout = 3s
request_slowlog_trace_depth = 50
pm.process_idle_timeout = 10s
pm.status_path = /status
php_admin_value[upload_tmp_dir] = /home/%user%/tmp
php_admin_value[session.save_path] = /home/%user%/tmp
php_admin_value[open_basedir] = /home/%user%/.composer:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/private:/home/%user%/web/%domain%/public_shtml:/home/%user%/tmp:/tmp:/var/www/html:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f admin@%domain%
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /home/%user%/tmp
env[TMPDIR] = /home/%user%/tmp
env[TEMP] = /home/%user%/tmp
I should mention that this is bare metal server.
CPU: Intel Xeon Gold 6140 (72) @ 3.700GHz
Memory: 8797MiB / 96312MiB
alber
October 24, 2024, 11:49am
3
MySQL configuration has some good settings but it may require adjustments for high traffic scenarios.
you should increase innodb_buffer_pool_size = 64G #Adjust based on available RAM
8000 connections is too high, Rather than setting a high max_connections, consider using ProxySQL.
Also, instead of solely increasing MySQL configuration, consider optimizing your software architecture by implementing a caching layer, such as Redis.
alber
October 24, 2024, 11:52am
4
You’re complicating the setup unnecessarily. You don’t need to proxy through Sucuri and then add a firewall on HestiaCP. You can manage everything through Cloudflare and effectively filter the traffic there.
alber
October 24, 2024, 11:54am
5
Is your server’s IP public? Cloudflare does a great job of hiding the origin IP address.
Changed:
and
max_connections=500
Using proxy sql is cool, but it’s just one wordpress site.
Yes ip’s public. But only traffic allowed is from cloudfalre and sucuri.
Cloudflare even with setting to ,under attack mode" was letting through lots of traffic.
Attackers are using residential proxys (smart proxy is the name if I’m correct). And the attack is originating from Android phones user agents and new versions of chrome. Attack is coming from UK and USA ( that’s where this site needs to work).
alber
October 24, 2024, 12:02pm
8
I’m not sure if you’re using a multisite WordPress setup or have many dynamic pages, but the server configuration you mentioned can easily handle 10k to 15k/RPS
eris
October 24, 2024, 12:04pm
9
Consider enabling FastCGI cache or Proxy cache.
Also use RedisDB or Memcached it saves to most used Mysql queries in Memory instead
It’s 1 wordpress page with microcache - 30 sec. Only thing that was dying is PHP-FPM or mariadb. PHP is no longer an issue since I tuned template to:
pm = ondemand
alber
11
Anotherbanana:
Yes ip’s public
did you proxy the server via cloudflare or not?
FastCGI is enabled : 30 sec
Redis is in place.
Opcache is working as well.
Yes it’s 100% behind Cloudflare.
When I was issuing SSL certificate if was off for few minutes and censys scraped my IP. That’s why I said it’s public, but it’s accessible only via Cloudflare.
eris
October 24, 2024, 12:08pm
14
FastCGI caching in Nginx enabled?
On what traffic load is the currently?
Please DM me the domain name?
I never had any issues with +10k active users with smaller server then yours currently…
alber
October 24, 2024, 12:09pm
15
If you’re managing a serious business, I suggest using Datadog or New Relic to profile performance and identify bottlenecks. Alternatively, consider using Docker for horizontal scaling.
alber
October 24, 2024, 12:10pm
16
In that case, you might want to change your IP address, lol.
FastCGI enabled.
Current load 1.35.
This mariadb instance is crashing only under short spikes in load.
I’ll send you DM soon.
I’m using New Relic to profile as well.
Will do it soon, but the traffic is coming from Cloudfalre —> Sucuri.
Any other access is blocked.
alber
October 24, 2024, 12:15pm
18
disable outside traffic on port 3306 and only allow localhost.
also in MySQL Configuration.
bind-address = 127.0.0.1
eris
October 24, 2024, 12:18pm
19
There doesn’t exists a firewall rule for Mysql so port is closed by default
Yes, from my understanding it should be closed.
