I installed Debain 10 HestiaCp to an OVH VPS
When MySql Db is uploaded the following error message is received
I have done the following changes
nano /etc/php/7.3/fpm/php.ini
error_reporting = E_ALL & ~ E_DEPRECATED & ~ E_STRICT
I changed it to:
error_reporting = ~ E_DEPRECATED & E_ALL.
When Vestacp changed it, it went right
My problem is still there
Hard to say exactly what your issue is, but I’ve seen something before with incompatibilities between the PHP version and the PHPmyadmin version. You could try changing one or other of these. Or at least tell us what you’re running.
It might also be due to PHPmyadmin needing a php module you don’t have installed. Any clues in the apache error logs?
