Hi there, I’ve faced an FATAL error during installation on Ubuntu 18.04.
() Configuring system settings…
() Configuring Hestia Control Panel…
() Generating default self-signed SSL certificate…
() Adding SSL certificate to Hestia Control Panel…
() Configuring NGINX…
() Configuring Apache Web Server…
() Configuring PHP-FPM…
() Configuring PHP…
() Configuring Vsftpd server…
() Configuring MariaDB database server…
Job for mariadb.service failed because the control process exited with error code.
See “systemctl status mariadb.service” and “journalctl -xe” for details.
Error: mariadb start failed
Jun 21 21:51:20 mypanel systemd[1]: Starting MariaDB 10.4.13 database server…
Jun 21 21:51:20 mypanel mysqld[3304]: 2020-06-21 21:51:20 0 [Note] /usr/sbin/mysqld (mysqld 10.4.13-MariaDB-1:10.4.13+maria~bionic) starting as process 3304 …
Jun 21 21:51:21 mypanel systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jun 21 21:51:21 mypanel systemd[1]: mariadb.service: Failed with result ‘exit-code’.
Jun 21 21:51:21 mypanel systemd[1]: Failed to start MariaDB 10.4.13 database server.
total 8
drwxr-xr-x 2 mysql mysql 4096 Jun 21 22:25 .
drwxr-xr-x 57 root root 4096 Jun 21 22:11 …
-rw-rw---- 1 mysql mysql 0 Jun 21 22:11 aria_log_control
-rw-r–r-- 1 root root 0 Jun 21 22:11 debian-10.4.flag
-rw-rw---- 1 mysql mysql 0 Jun 21 22:11 ibdata1
The issue is fixed now, unfortunately my provider made a mistake and gave me only 5GB hard disk space, so HestiaCP installation failed without any known and vivid error.
So as a suggestion I suggest adding the following features in the next releases:
1- before starting the installation check if the system has at least 13GB free space.
2- When we change the default port by using --port 5600 ,in the installation output it still says 8083:
Admin URL: https://my.panel.com:8083
3- After completion of the installation it says: it needs to be rebooted, Are u sure to reboot? choose [Y/N]
This is written in the last line which most of people pay attention to only this line, while the most important part of the output is this:
Username: admin
Password: bpUCX5sagX5Fz2Dk1
So before let him reboot, tell him: hey man, don’t forget to copy the provided Username+Password somewhere else and now Are u sure to reboot? choose [Y/N]
This is due to a missleading installation string, in your case the --force parameter - this one should be on last position. This is in some way a known issue with the external install string generator - we currently work on a own implementation (which is already in our github repository, but not yet on our website): https://github.com/hestiacp/hestiacp-generator
Probaly v-change-user-password is your new friend after a direct reboot, but you should also get a email with the credentials (or should get, it may be stopped due to wrong spf records or anti spam). So there is no additional change needed.
Edit: I’ve cloned it myself and used it, thanks.
One more question: I’ve added —port 5602 parameter but at last I’ve surprisingly seen that it still uses the port 8083 Why? How to change port? is it also because of missleading installation string of --force?
