When installing the latest version of Hestia on Ubuntu 20.04 LTS, there was an error when installing MariaDB and public key. Now this error keeps coming up when installing updates:
Err:8 https://dlm.mariadb.com/repo/mariadb-server/10.6/repo/ubuntu focal InRelease
The following signatures cannot be verified because the public key is not available: NO_PUBKEY F1656F24C74CD1D8
Help fix it!
It is impossible to reinstall Ubuntu. Sevrer only remotely.
Та же история. Сначала написала что синтаксис адреса нарушен, заменил кавычки и убрал их совсем. Ситуация не изменилась.
Same thing. First wrote that the address syntax is broken, replaced the quotes and removed them altogether. The situation has not changed.
К сожалению не работает. Уже попробовал сверху накататить установку
sudo apt install mariadb-server
ошибка ключа F1656F24C74CD1D8 сохранилась.
Unfortunately, it does not work. Already tried installing over the top
The key error F1656F24C74CD1D8 is still present.
