Mariadb repos failing
Getting this on a few hestia hosts.
E: The repository https://mirror.mva-n.net/mariadb/repo/10.5/ubuntu focal Release no longer has a Release file.
And also for the 10.6 version.
Not alarming at the moment, and maybe just a transient thing, but thought I’d mention it.
Same problem with 10.4.
E: The repository 'https://mirror.mva-n.net/mariadb/repo/10.4/ubuntu focal Release' no longer has a Release file.
Instead of Switzerland mirror mirror.mva-n.net you could try another one like this from Oporto University (I tested it and it works):
mirrors.up.pt
This is common in mariadb mirros, I take one oficial mirror from mariadb.org After 3 weeks it was no longer available
Visit Download MariaDB Server - MariaDB.org and get new one
You can also use yum.mariadb.org this never change, but may is slow in your location.
Thank you. I’ve chosen an Austrian mirror from Download MariaDB Server - MariaDB.org, since my server’s in Austria.
We have changed it on newer installs to
https://dlm.mariadb.com/repo/mariadb-server/$mariadb_v/repo/$VERSION $codename main
And it seem to be working fine …
My line in /etc/apt/sources.list.d/mariadb.list remains:
deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/debian bookworm main
Thanks.
I said it in your other post but don’t use 11.3, it is the development version, use 11.2 instead if you want to use 11.x.
Doesn’t work anymore, also official script now fails with error
The repository 'https://dlm.mariadb.com/repo/maxscale/latest/apt noble Release' does not have a Release file.
Check Installer script max scale can’t be right…
Check the link. It will show 404
For example
You shouldn’t test the repo trying to access that url directly, it won’t work that way on that repo.
If you want to test the repo for mariadb-server version 10.11 and Ubuntu Noble, use this link:
https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/dists/noble/main/binary-amd64/Packages.gz
And here the link to download the deb:
https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-server_10.11.8+maria~ubu2404_amd64.deb
Anyway, Hestia doesn’t support Ubuntu Noble yet.
Not “Released” yet… Main brand allready supports it…
