Hello, since some days I experience massive incoming spam attacks on all hosted domains. I block a lot of tld’s through exim config but would their be a way to just block the ip address after a few attempts sending to non-existent e-mail addresses? Now it just goes on and on throughout the day.
Thanks in advance
2023-05-23 00:10:12 H=110-25-99-34.adsl.fetnet.net [110.25.99.34] F=<[email protected]> rejected RCPT <[email protected]>: Your tld has been blacklisted for sending SPAM.
2023-05-23 22:45:23 H=(188.22.189.118.static.m1net.com.sg) [118.189.22.188] F=<[email protected]> rejected RCPT <[email protected]>: Your tld has been blacklisted for sending SPAM.
Thank you very much @eris. I updated /etc/fail2ban/jail.conf and restarted fail2ban + a server reboot but it didn’t work just yet. Any other thoughts on how to solve this?
2023-05-24 09:50:26 H=([185.255.212.178]) [185.255.212.178] F=<[email protected]> rejected RCPT <[email protected]>: Your tld has been blacklisted for sending SPAM.
2023-05-24 09:50:26 H=([185.255.212.178]) [185.255.212.178] F=<[email protected]> rejected RCPT <bs[email protected]>: Your tld has been blacklisted for sending SPAM.
2023-05-24 09:50:26 H=([185.255.212.178]) [185.255.212.178] F=<6l2312vjlu5d6[email protected]> rejected RCPT <[email protected]>: Your tld has been blacklisted for sending SPAM.
Okey thank you i’ll disable that to see if it works. Is there a way to set an order of effect?
Btw. It also doesn’t work for incoming messages (200 attempts in a split second: literally one hundredth of a second) that are aren’t blocked by my tld list but blocked because of spamcop.net.
2023-05-24 10:09:16 H=([130.185.96.109]) [130.185.96.109] F=<[email protected]> rejected RCPT <[email protected]>: Rejected because 130.185.96.109 is in a black list at bl.spamcop.net
2023-05-24 10:09:16 H=([130.185.96.109]) [130.185.96.109] F=<[email protected]> rejected RCPT <gde2r3d6b[email protected]>: Rejected because 130.185.96.109 is in a black list at bl.spamcop.net
Thank you! I’ll give that a try this afternoon. I do use my own custom ipsets to block different countries and ASN’s. I also have the default blacklist enabled in my firewall. How would I create a custom ipset from the logged ip’s in exim? Kind regards
Same attack here. I am using dns based blacklists and the senders of this attack are listed on that. Still, they are hammering the door multiple times a second.
I noticed that they are trying to deliver multiple messages in one smtp session.
Exim tells them they are listed on the blacklist, but then waits for the next command in the same smtp session. Better is to have exim drop that smtp session after the blacklist message. You might even consider to delay exim a bit before sending the blacklist message.
This all helps for fail2ban to eventually ban them.
Thank you @maurice, I just changed according to your suggestion:
drop message = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
hosts = !+whitelist
dnslists = ${readfile {/etc/exim4/dnsbl.conf}{:}}
delay = 8s
I think that fail2ban only effects new incoming tcp connections, not existing ones. This spamrun tries to deliver numerous message in one single smtp connection, hence we need exim to drop the connection instead of denying the message.
Don’t forget to restart exim after you make changes to the config.
Thanks again @maurice. I observed the logs since yesterday and noticed less peak attacks but there is still a continuous stream of incoming attempts. Would there also be a way to drop any attempt that is rejected because of being listed at bl.spamcop.net? Any other ideas would also be highly appreciated. Thanks!
Basically you can’t completely stop the attack. You can reduce the volume by using RBL for spam specifically like “nixspam“ as i did on my PFSense.
And if you can use anti-spam system before your panel.
I don’t know if you can add a dns blacklist in the gui (webinterface) of hestia, but you can define them in the file /etc/exim4/dnsbl.conf
With the modifications you did earlier, you will actually drop any attempt that is rejected because of being listed.
