Max Theme for HestiaCP
maxtheme-dark-light
Hello everyone, I have recently released a new, completely improved versión of MaxTheme for HestiaCP in Dark and Light versions with 14 color variations, not many may know of its existence, so I am leaving you the Github repository.
Repository with installation instructions:
I have tried to give it a more modern and elegant design, any comments are welcome to improve the theme in future updates.
Hi @Maxi,
Great! Thanks for sharing :+1: :hugs:
Where can I find similar plugins?
For example, I need the systemd manager plugin
Install it directly and switch it. Check out the github homepage
Thank you @Maxi. Wonderful.
@Maxi Will surely try it out in a day or 2. Looks glamourous. :slight_smile:
Your photopea one also looks worth trying. Hope you will update it on regular basis both the HCP and PP one?
Sure, I’ll try to update it frequently, any recommendations are welcome, Greetings.
Couple of suggestions. The fonts and page space/area at the tope is very big upon installation. Suggest to minimize that.
Allow for more than one pattern to install in one go. Let the users choose from one or many or all, selection based.
Otherwise, awesome. :slight_smile:
Yes very nice! I wonder if theres enough time to merge it into the next 1.9 release maybe even make it a default.
Why not submit a PR to hestia Repo for this one
You’re awesome !
Great work :slight_smile:
Estupendo tema!! Muchas gracias por compartir! :slight_smile:
Very good! It would be great to see new versions along the lines of cPanel or KeyHelp…
