We have Hestiacp installed on Debian 11. It is a Virtual Machine and it has 1 socket, 2 Cores, 4GB Ram, 100GB Hdd.
We would like to know what is the limit of maximum sending emails in one minute in Hestiacp?
Thanks.
Thanks.
You can search for send limits for exim, which hestia uses as mta. There are no known max send email frequenzy from our side.
Without any config changes 200 /hr
Thank you for your replies. 200 emails per hour? It is not high. Is there any way to increase it?
Yes see exim4 config or better wait untill 1.6 release then it is even easier
Thank you very much for your information.
