May I know how to close the IP access management port or modify the management port
I just want to access the management service through the domain name and port. Thank you!
A makeshift: edit /usr/local/hestia/nginx/conf/nginx.conf.
The area:
# Vhost
listen 8083 ssl;
server_name _;
To:
# Vhost
server {
listen 8083 ssl;
server_name IPADDRESS;
root /var/www/html;
ssl_certificate /usr/local/hestia/ssl/certificate.crt;
ssl_certificate_key /usr/local/hestia/ssl/certificate.key;
server {
listen 8083 ssl;
server_name HOSTNAME;
