Messages during the installation
I installed Hestia, but during the installation, I received two error messages saying ‘unable to start systemd-timesyncd.services.’ Just wondering if this is something to worry about?
OS: Debian 12
If you already have another sync time daemon then you should not be worried about that message.
Run the command:
timedatectl
And if you see this:
System clock synchronized: yes
              NTP service: active
Then all should be ok because you are running other time sync daemon like ntp or chrony.
