Migrating from plesk to HestiaCP
I’m new to this panel and I’m very green on the subject.
I am migrating my server from Plesk to Hestia, everything is fine.
except for how Plesk’s open_basedir deals:
open_basedir: {WEBSPACEROOT}{/}{:}{TMP}{/} (Default)
and now when transferring the first Prestashop domain of 2 that I have.
I get these errors
Warning: file_exists(): open_basedir restriction in effect. File(/views/templates/hook/ht_newsinclude.tpl) is not within the allowed path(s): (/home/pedraja/.composer:/home/pedraja/web/pedraja.com.es/public_html:/home/ pedraja/web/pedraja.com.es/private:/home/pedraja/web/pedraja.com.es/public_shtml:/home/pedraja/tmp:/tmp:/bin:/usr/bin:/usr/local/ bin:/usr/share:/opt) in /home/pedraja/web/pedraja.com.es/public_html/classes/module/Module.php on line 2289
I have copied the php.ini verbatim so that it has the same memory and config. and I’m still the same…
My other question is how do I transfer the 30GB of .netxcloud. any ideas.
Thank you so much
Create a new PHP-FPM template with format like
YOURNAME-PHP-X_Y.tpl
See: Web Templates and FastCGI/Proxy Cache | Hestia Control Panel
And add :/ to the open base dir value
Fixed Prestashop bug, update it
I already have everything solved, thank you very much.
Now I am transferring mail, let’s hope I don’t need any more help, thank you very much.
Maybe this can help if you need to do more then user more …
Requires root admin on the Plesk server
@harlek did it work?
No, in the end I did everything by hand.
I uploaded the emails through an imapsync website
taken from this forum.
The Prestashop website is solved by updating.
What happens to me is that this morning I wake up and find this like this.
Check /var/log/hestia/nginx-error.log
https://pedraja.es/log/nginx-error.log
“PHP message: PHP Parse error: Unclosed ‘{’ on line 37 in /usr/local/hestia/web/templates/pages/list_web.php on line 346”
I don’t see anything wrong…
We also have not released any update yesterday / today / this week
some command like the one plesk had
plesk repair installation or
plesk repair all
I just realized that I can’t modify anything with the admin user.
I can’t modify anything in nginx or apache from the web.
/list/server/
apt-get install --reinstall hestia
Will reinstall the package…
[ * ] Rebuilding user accounts and domains, this may take a few minutes...
      - hestiamail...
      - admin...
      - pedraja...
[ * ] Restarting services...
Upgrade complete! If you encounter any issues or find a bug,
please take a moment to report it to us on GitHub at the UR
and we continue the same!!!
ok reinstall the entire VPS new installation of ubuntu and hestia
How do I use this???
I put .sh??
I don’t think it will help… As it won’t fix any php error codes if the exist…
Do you mind sharing ssh details so I can have a look? (Via DM?)
