Misdirected Request error after generating SSL certificate
After generating an SSL certificate for my domain on Hestia CP, I started getting the following error when accessing my site via HTTPS:
Misdirected Request – The client needs a new connection for this request as the requested host name does not match the Server Name Indication (SNI) in use for this connection.
HTTP (port 80) works perfectly fine.
The issue appears only after generating the SSL certificate and enabling HTTPS (port 443).
I have checked my nginx configuration and the server_name directive seems correct.
I suspect there might be a problem with port handling or virtual host configurations on the server.
Has anyone experienced this issue before? Any advice or solutions would be greatly appreciated.
Thank you!
i have the same issue after update apache2 on my server
Misdirected Request
how to fix?
use this command:
my server now work again.
Exactly.
Thank you very much!
I had the issue as well after updating. My SSL is paid for so why should this happen and again, its only the website that is up, the webmail is still down, any ideas
Thanks Bro
Thank you very much. Worked for me too.
