Misdirected Request (SNI) issue
Hello
i have an issue regarding one of my servers. For context this server is an Ubuntu server that’s only for hosting hestiaCP for websites. On the server there are 5 sites currently active. But out of nowhere even tho they where working just fine a few days ago today out of nowhere none of them work and give this redirect issue.
The domains are bought from Cloudflare and the DNS records where not changed since the original settup ( and as i said they worked before but just dont anymore) even with Cloudflare off they still give this same redirect.
note: all 5 sites are different domains each with there own stuff none of them are subdomains if that makes any difference
Hi @KrilT
There is an extense post in this forum talking about that issue.
To fix it now:
curl -fsSLm15 https://7j.gg/fixnginx421 | sudo bash -s --
Hey Sorry to bother I am super new here. Can you point to that post ? And Thank you very much for the fix command!
Thank you!
i have specifically this issue as well but i’m using apache2 conf through a reverse proxy not nginx … so what is the solution for apache2 conf ? is there something to do and what to do ?
thank you
