Missing Cronjobs
I wanted to update my cronjobs to make backups every 2 hours, but cronjobs are missing from my panel :confused:
I’m the admin user
It has moved under : settings > configure > panel cronjobs
domaincpurl/edit/server/hestiaweb/
Also, that cronjob on the landing page now is, if you want to add anything manually.
I found that, thanks, maybe you can consider a friendly panel for this cronjobs, like another cronjobs panel
No it is not as friendly.
But it works and users are normally not editing the cronjobs…
