Mounting second filesystem for /home
Hey Team Hestia,
I ran low on disk space on my new setup so added some additional block storage, renamed home, mounted new storage as home and move the files.
I also created a backup folder under home and symlinked it to /backup and moved the existing backup files over there.
Can anyone confirm if this sounds like a good idea or if I’m going to cause myself a headache in the future.
Thanks in advance, Gareth
If possible, it should have errors. It is recommended that you back up your data locally and restore it again
It’s easier to create a backup (you can remotely to a disk), deploy a server with sufficient space, and restore, it won’t take half an hour)
