Moving from CloudFlare help
Hello community,
I hope you are well <3
I have an issue with cloudflare, specificly with mail config.
I tried too much solutions but there is no way to solve it so im tired.
The problem is with DKIM sig. its always invalid, I tried to much but there is no solu.
so, in other hand i have other server connected dircte with namecheap and i got 10/10 score and i love it.
the Question is: can I move from the cloudflare to connect the hestiacp with namecheap dircte ? without any affects on the site or server or mails ?
and can I get the score 10/10 without reinstall hestiacp ?
any suggestions ?
Hi @inj3ct0r,
Are you sure you are using the right public key on your dns conf?
Exececute below commands as root, the output must be the same (replace YourUser and YourDomain with the actual data):
 v-list-mail-domain-dkim-dns YourUser YourDomain | tail -n1 | awk '{print $5,$6,$7}' | tr -d ' "' | md5sum
 dig txt mail._domainkey.YourDomain +short | tr -d ' "' | md5sum
I talked to sahsanu in private to keep some information priv8.
he helped me alot and solve the problem
the problem was in multi line copy paste of DKIM in cloud flare
thank you alot bro you are amazing
thanks for helping me again I appreceate your effort and time.
Thats a good catch. Drove me crazy for a few days a while back. I wasnt on CF though. just bind on the cli
