Hello All,
I cannot see multiple php versions to choose for my websites in hestiacp.
Is it because I have installed hestia with debian package and not with script and multiphp is not enabled now?
So how can I switch to multi php?
Thanks in advance
Cheers
Thomas
eris
January 19, 2021, 11:23pm
2
Reinstall and use the script…
As we add also other software programs…
so I can just uninstall via apt and then install with script?
this will not break my configuration, users, domains …?
thanks
Lupu
January 20, 2021, 6:08am
4
To be clear, how did you install hestiacp wihout script? have you just run dpkg -i hestia.deb
sorry, sorry.
I installed 1 1/2 years ago, I thought I did “apt install hestia”, but thanks history, sure I used the script.
So question again, why can’t I choose the php version?
Still you think I should reinstall with script? This will not break conifg?
eris
January 20, 2021, 8:29am
6
v-add-web-php your version
If it will install any version you want
thanks. In meantime I tried that already, but still cannot pick the PHP version. see here:
thanks
eris
January 20, 2021, 9:29am
8
Your are still using modphp that does not support multiphp
Please check:
That soilved it.
Thanks a lot
system
Closed
February 21, 2021, 8:55am
10
