Multiple IP addresses for remote access in firewall
Good day!
It is not entirely clear how to set up 2 (or more) addresses in the firewall to control, for example, MySQL from an external network using, for example, Navicat. The ISP implements this by adding a line for entering the IP, but how to do it here?
Thank you in advance.
Add multiple rules under the firewall settings for the mysql port. If you have more than 10 addresses, you could also add an ipset list.
That is, there is 1 line of the rule for 1 address, right I understand? (addresses 2 or 3 will be)
Yes. 1 line per adress
