if anyone uses GitHub - denisidoro/navi: An interactive cheatsheet tool for the command-line
" navi allows you to browse through cheatsheets (that you may write yourself or download from maintainers) and execute commands. Suggested values for arguments are dynamically displayed in a list."
I made one for Hestiacp CLI it includes variables for the commands so you can search a command and then it will have you type in the fields needed for the command and then output the command.
It comes in handy if you can’t remember one specifically.
