Need help with maverick version in docker
Hello, I use the translator to converse here. By the way, why can’t the browser translate your forum? I can’t reply to this post (link below) either, so I created this one.
Already @jhmaverick I wanted to congratulate you because 2 years later, there is only your version of hestia-cp that works in docker on my NAS. (Which is much better than an old version of vesta-cp.)
Since I found you here in the forum, I wanted to ask you how do you get webmail to work? I installed Roundcube in a container that I connected from the container of your version of hestia, but I can’t connect it.
I also have a problem pointing the domain instead of seeing the ip in the address bar. I can’t do it.
And there is let’s encrypt which refuses to validate. Probably because having a synology, I have a section for let’s encrypt. Here I try a subdomain which is voluntarily not put in the SSL section of the NAS compared to the domain in question.
Can you help me solve these 3 problems? Thank you in advance.
Hestia does not officially support Docker and is developed by enthusiasts. We suggest that you consult the Docker version owner
Thank you for your answer. This is what I am trying to do. I put the person’s name in the title and I don’t know where to contact them.
If we can’t have Hestia-cp in docker, on the NAS it is impossible to install, especially with the synology DSM system. Docker is our only solution.
Kind regards.
https://hgithub.xyz/jhmaverick/hestiacp-docker
But it archived / EOL
It should have stopped updating.
Hestia isnt realy supposed to run on a nas…
