Need help with update to php 8.3 & 8.4
HI guys set error after sudo apt-get upgrade
root@server:~# sudo apt-get upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  debsuryorg-archive-keyring libdaxctl1 libdw1 libndctl6 libpmem1 libsodium27 libvpx8 libx265-209
  php8.3-memcached php8.3-redis php8.4-redis
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  cloud-init distro-info-data ethtool ffmpeg galera-4 libaom3 libavcodec58 libavdevice58 libavfilter7
  libavformat58 libavutil56 libfftw3-double3 libldap-2.5-0 libldap-common libmariadb3 libmpg123-0
  libnss-systemd libopenmpt0 libpam-systemd libpostproc55 libsdl2-2.0-0 libswresample3 libswscale5
  libsystemd0 libudev1 linux-base mariadb-client mariadb-client-core mariadb-common mariadb-server
  mariadb-server-core mysql-common pci.ids php-common php5.6-imagick php7.0-imagick php7.1-imagick
  php7.2-imagick php7.3-imagick php7.4-imagick php8.0-imagick php8.1-imagick php8.3-cli php8.3-common
  php8.3-opcache php8.3-phpdbg php8.3-readline php8.4-cli php8.4-common php8.4-opcache php8.4-phpdbg
  php8.4-readline sosreport systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
  ubuntu-pro-client ubuntu-pro-client-l10n udev
60 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 35.4 MB/59.9 MB of archives.
After this operation, 225 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mysql-common all 1:10.11.12+maria~ubu2204
  404  Not Found [IP: 2606:4700::6811:bf0e 443]
Err:2 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mariadb-common all 1:10.11.12+maria~ubu2204
Err:3 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.3-readline amd64 8.3.20-1+ubuntu22.04.1+deb.sury.org+1
  404  Not Found [IP: 2620:2d:4000:1::81 443]
Err:4 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.3-opcache amd64 8.3.20-1+ubuntu22.04.1+deb.sury.org+1
Err:5 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.3-phpdbg amd64 8.3.20-1+ubuntu22.04.1+deb.sury.org+1
Err:6 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.3-cli amd64 8.3.20-1+ubuntu22.04.1+deb.sury.org+1
Err:7 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.3-common amd64 8.3.20-1+ubuntu22.04.1+deb.sury.org+1
Err:8 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.4-readline amd64 8.4.6-1+ubuntu22.04.1+deb.sury.org+1
Err:9 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.4-opcache amd64 8.4.6-1+ubuntu22.04.1+deb.sury.org+1
Err:10 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.4-phpdbg amd64 8.4.6-1+ubuntu22.04.1+deb.sury.org+1
Err:11 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.4-cli amd64 8.4.6-1+ubuntu22.04.1+deb.sury.org+1
Err:12 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy/main amd64 php8.4-common amd64 8.4.6-1+ubuntu22.04.1+deb.sury.org+1
Err:13 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 libmariadb3 amd64 1:10.11.12+maria~ubu2204
Err:14 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mariadb-client-core amd64 1:10.11.12+maria~ubu2204
Err:15 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mariadb-server amd64 1:10.11.12+maria~ubu2204
Err:16 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mariadb-client amd64 1:10.11.12+maria~ubu2204
Err:17 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 mariadb-server-core amd64 1:10.11.12+maria~ubu2204
Err:18 https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu jammy/main amd64 galera-4 amd64 26.4.22-ubu2204
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mysql-common_10.11.12%2bmaria%7eubu2204_all.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-common_10.11.12%2bmaria%7eubu2204_all.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/libmariadb3_10.11.12%2bmaria%7eubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-client-core_10.11.12%2bmaria%7eubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-server_10.11.12%2bmaria%7eubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-client_10.11.12%2bmaria%7eubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/m/mariadb/mariadb-server-core_10.11.12%2bmaria%7eubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/ubuntu/pool/main/g/galera-4/galera-4_26.4.22-ubu2204_amd64.deb  404  Not Found [IP: 2606:4700::6811:bf0e 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.3/php8.3-readline_8.3.20-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.3/php8.3-opcache_8.3.20-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.3/php8.3-phpdbg_8.3.20-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.3/php8.3-cli_8.3.20-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.3/php8.3-common_8.3.20-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.4/php8.4-readline_8.4.6-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.4/php8.4-opcache_8.4.6-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.4/php8.4-phpdbg_8.4.6-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.4/php8.4-cli_8.4.6-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Failed to fetch https://ppa.launchpadcontent.net/ondrej/php/ubuntu/pool/main/p/php8.4/php8.4-common_8.4.6-1%2bubuntu22.04.1%2bdeb.sury.org%2b1_amd64.deb  404  Not Found [IP: 2620:2d:4000:1::81 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@server:~#
Maybe these will help:
MariaDB Repo Guide
PHP
Hi @vladimirb1
Regarding 404 errors for mariadb:
sudo rm /var/lib/apt/lists/dlm.mariadb.com_repo_mariadb-server_*
PHP repo should work, try to force the use of IPv4:
sudo apt -o Acquire::ForceIPv4=true update
sudo apt -o Acquire::ForceIPv4=true full-upgrade
