Need .phtml support in hestia
I’ve migrate from vesta and have legacy with tons of phtml files. Now .phtml files open as just .html files - raw php-code showing in browser. What should I do to add .phtml support into Hestia(globaly or just for domain)?
Nginx or Apache2?
Global answer check how php is handleld in the correct template and modify according it also accept .phtml
Default Hestia installation - all templates are default also.
What I did:
  1. Edited “/usr/local/hestia/data/templates/web/apache2/php-fpm/default.tpl”(and stpl)
    Replaced: <FilesMatch \.php$> by <FilesMatch \.(php|phtml)$>
  2. Added security.limit_extensions = .php .phtml in to the “/usr/local/hestia/data/templates/web/php-fpm/default.tpl”
  3. Restarted apache,nginx and php-fpm via Hestia GUI.
But .phtml source still shows in browser instead handeling by php.
Did you run v-rebuild-web-domain user domain.com ?
The following templates work fine for me…
phtml.tpl (FPM config)
; origin-src: deb/templates/web/php-fpm/default.tpl
[%backend%]
listen = /run/php/php%backend_version%-fpm-%domain%.sock
listen.owner = %user%
listen.group = www-data
listen.mode = 0660
user = %user%
group = %user%
pm = ondemand
pm.max_children = 8
pm.max_requests = 4000
pm.process_idle_timeout = 10s
pm.status_path = /status
php_admin_value[upload_tmp_dir] = /home/%user%/tmp
php_admin_value[session.save_path] = /home/%user%/tmp
php_admin_value[open_basedir] = /home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/public_shtml:/home/%user%/tmp:/var/www/htm$
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f admin@%domain%
env[HOSTNAME] = $HOSTNAME
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /home/%user%/tmp
env[TMPDIR] = /home/%user%/tmp
env[TEMP] = /home/%user%/tmp
And
phtml.stpl
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
<VirtualHost %ip%:%web_ssl_port%>
    ServerName %domain_idn%
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %sdocroot%
    ScriptAlias /cgi-bin/ %home%/%user%/web/%domain%/cgi-bin/
    Alias /vstats/ %home%/%user%/web/%domain%/stats/
    Alias /error/ %home%/%user%/web/%domain%/document_errors/
    #SuexecUserGroup %user% %group%
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
    <Directory %home%/%user%/web/%domain%/stats>
        AllowOverride All
    </Directory>
    <Directory %sdocroot%>
        AllowOverride All
        SSLRequireSSL
        Options +Includes -Indexes +ExecCGI
	</Directory>
    SSLEngine on
    SSLVerifyClient none
    SSLCertificateFile %ssl_crt%
    SSLCertificateKeyFile %ssl_key%
    %ssl_ca_str%SSLCertificateChainFile %ssl_ca%
    SetHandler "proxy:%backend_lsnr%|fcgi://localhost"
    </FilesMatch>
    SetEnvIf Authorization .+ HTTP_AUTHORIZATION=$0
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.ssl.conf_*
</VirtualHost>
phtml.tpl
<VirtualHost %ip%:%web_port%>
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %docroot%
    IncludeOptional %home%/%user%/conf/web/%domain%/apache2.forcessl.conf*
        AllowOverride All
    </Directory>
        AllowOverride All
    </Directory>
    </FilesMatch>
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.conf_*
</VirtualHost>
Cool! Thank you!
v-rebuild-web-domain helped me
Please make sure that you don’t over write default default templates
They got often over written during upgrades
