Need to create 400+ emails
Hi there, is there any import function in hestiacp to make bulk email accounts at once?
The only import function that I know is v-import-cpanel to import all data from a cpanel backup but seems is not what you are looking for.
If you have all the data in a text file you can create a script to add all of them using v-add-mail-account
Data that you will need in that file:
USER DOMAIN ACCOUNT PASSWORD [QUOTA]
No,
But I can be done via bash or even php if you have a file. But it depends on how it looks …
am not that technical tho, but after creating the text file
i will need to run the command like this?
v-add-mail-account file.txt
Thanks i figured it out and done
That won’t work …
If the file looks like:
user,test.com,jaap,123456ABCD
user,test.com,jaap2,123456ABCD
Then:
#/bin/bash
while IFS="," read -r user domain account password
do
   v-add-mail-account "$user" "$domain" "$account" "$password"
done < email.txt
You can also just create a file containing $account and $password and then hard code the missing values…
But without knowing how the text file looks like I have no idea how to do it exactly…
I didn’t know hestia supports import for Cpanel. Should add it to the documentation for restoring.
v-import-cpanel
Source
Import Cpanel backup to a new user
Options: BACKUP [MX]
Examples:
bash
v-import-cpanel /backup/backup.tar.gz yes
Based on sk-import-cpanel-backup-to-vestacp Credits: Maks Usmanov (skamasle) and contributors: Thanks to Contributors to Skamasle/sk-import-cpanel-backup-to-vestacp · GitHub
