Hello Everyone
My VPS is on Debian 12 with Hestiacp 1.9.3
I need to open port 8081 and 8082 because i need for my phyton and node.js project.
How to do it? Thanks in advance
Hello Everyone
2 ways.
One via CLI: CLI Reference | Hestia Control Panel
Example: v-add-firewall-chain CRM 5678 TCP
Second via the UI: Settings > Firewall > Add Rule > add the port as needed.
Not working, still time-out.
Is it need to do with iptables config?
Ohh. I forgot, need to reload/restart iptables and firewall. My bad.
You don’t need to add a chain, just add the right rule to open those ports:
v-add-firewall-rule ACCEPT '0.0.0.0/0' '8081,8082' TCP pynode
If that doesn’t work, show the output of these commands:
v-list-firewall
iptables -S
Sorry my bad. @pakdhetimin apologies for the confusion I caused.
However, you can add them via the UI as I mentioned and just reload the firewall and you are done.
RULE ACTION PROTO PORT IP SPND DATE
1 ACCEPT ICMP 0 0.0.0.0/0 no 2014-09-16
2 ACCEPT TCP 8083 0.0.0.0/0 no 2014-05-25
3 ACCEPT TCP 143,993 0.0.0.0/0 no 2014-05-25
4 ACCEPT TCP 110,995 0.0.0.0/0 no 2014-05-25
5 ACCEPT TCP 25,465,587 0.0.0.0/0 no 2018-11-07
6 ACCEPT TCP 53 0.0.0.0/0 no 2014-05-25
7 ACCEPT UDP 53 0.0.0.0/0 no 2014-05-25
8 ACCEPT TCP 21,12000-12100 0.0.0.0/0 no 2014-05-25
9 ACCEPT TCP 80,443 0.0.0.0/0 no 2014-09-24
10 ACCEPT TCP 22 0.0.0.0/0 no 2014-09-16
11 ACCEPT TCP 3306,5432 0.0.0.0/0 no 2025-06-08
12 ACCEPT TCP 8081,8082 0.0.0.0/0 no 2025-06-09
-P INPUT DROP
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-N fail2ban-FTP
-N fail2ban-HESTIA
-N fail2ban-MAIL
-N fail2ban-RECIDIVE
-N fail2ban-SSH
-N fail2ban-WEB
-N hestia
-A INPUT -p tcp -m multiport --dports 25,465,587,110,995,143,993 -j fail2ban-MAIL
-A INPUT -p tcp -m tcp --dport 21 -j fail2ban-FTP
-A INPUT -p tcp -m tcp --dport 22 -j fail2ban-SSH
-A INPUT -p tcp -m tcp --dport 8083 -j fail2ban-HESTIA
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -s 172.16.32.75/32 -j ACCEPT
-A INPUT -s 127.0.0.1/32 -j ACCEPT
-A INPUT -p tcp -m multiport --dports 8081,8082 -j ACCEPT
-A INPUT -p tcp -m multiport --dports 3306,5432 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p tcp -m multiport --dports 21,12000:12100 -j ACCEPT
-A INPUT -p udp -m udp --dport 53 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 53 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 8083 -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A fail2ban-FTP -j RETURN
-A fail2ban-HESTIA -j RETURN
-A fail2ban-MAIL -j RETURN
-A fail2ban-RECIDIVE -s 91.205.219.185/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 80.93.199.153/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 61.222.211.114/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 222.107.251.147/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 216.55.137.59/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 188.83.71.207/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 172.208.24.217/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 152.32.145.111/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 139.59.24.220/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-SSH -j RETURN
-A fail2ban-WEB -j RETURN
here is the output, and still 8081 and 8082 have timeout when i check with DNSchecker.org for open port check
probaly another firewall in front of it?
i am using alibaba cloud ecs and already add rules in security group to include port 8081 and 8082 in allowed traffic.
curl http://127.0.0.1:8081 ist working?
telnet YOUR_SERVER_IP 8081
# or
nc -zv YOUR_SERVER_IP 8081
sudo tcpdump -n port 8081
Then try to access the port again from another machine.
If you see nothing, the request never even reaches the server → likely a firewall or NAT/router issue.
If you see packets, but the service doesn’t respond → likely an application issue or local firewall.
I prefer to proxy them using nginx, that way is more easy (and guess secure) to handle ssl certificates. This is done creating a custom nginx template and assign it on the control panel.
