Hi
I am with a problem in add new IP to hestia …
My DC is using vlan setup, and, in hestiacp panel, is not showing the correct interface to select.
In olds hestiacp versions, this worked …
I have another server installed with debian10, in the past, was possible select correct interfaces and additional ips worked .. but today, I tested in this same server and too not working anymore ( the old IPs created are working, but new add not )
In new hestia install ubuntu 22.04 I not able to add IPs
My DC uses like this:
Block: xxx.xxx.xxx.xxx / 28
VLAN: 3894
Gateway: xxx.xxx.xxx.xxx
IP’s : xxx.xxx.xxx.xxx - xxx.xxx.xxx.xxx
bond0: flags=5187<UP,BROADCAST,RUNNING,MASTER,MULTICAST> mtu 1500
ether aa:aa:aa:aa:xx:xx txqueuelen 1000 (Ethernet)
RX packets 13774194547 bytes 2292406696914 (2.0 TiB)
RX errors 704 dropped 20260 overruns 0 frame 0
TX packets 26305334910 bytes 30300653537457 (27.5 TiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
bond0.598: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.32.9.50 netmask 255.255.255.240 broadcast 10.32.9.63
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 6 bytes 536 (536.0 B)
bond0.1697: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet xxx.xxx.xxx.xxx netmask 255.255.255.248 broadcast xxx.xxx.xxx.xxx
RX packets 13582546550 bytes 2089939033456 (1.9 TiB)
TX packets 15271562809 bytes 29587292092251 (26.9 TiB)
eno1: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
TX packets 26304485379 bytes 30300548195613 (27.5 TiB)
eno2: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
TX packets 849531 bytes 105341844 (100.4 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 1831276641 bytes 7097177572478 (6.4 TiB)
TX packets 1831276641 bytes 7097177572478 (6.4 TiB)
In hestiacp interfaces, show me eno1 eno2 .. but the correct will be bond0.1697
How I could procced to add correctly new IPs ?
Thanks!!
