sudo bash hst-install.sh -a yes -n yes -w no -o no -v yes -j no -k yes -m yes -g no -x yes -z yes -c yes -t yes -i yes -b yes -q no -d yes -f no -y yes -r yes -e no -p no -l no
Please also share the error message you got . Also please write out your installation command, usualy hestia ships itself with vsftpd but a switch to proftpd would work.
First of all, thank you for the quick response.
This shows that hestiacp is quite moderate.
I managed to identify the error.
When creating the user, I put it as capital letters, and when I tried to log in to FTP I need to login as morecle capital letters, otherwise it won’t work.
I had to change the folder permissions for the page to be visible on the web, according to the commands below
