just starting with HestiaCP, read a lot of posts but still can’t figure out something.
I added my domains into the control panel, they are registered with Hostinger. nslookup of checks on http://whatsmydns.net/ shows it’s propagated.
Then when I add those domains into the control panel and tell them to add a Let’s Encrypt certificate, it ends up with the infamous “Error: Let’s Encrypt finalize bad status 403” message.
Now, I wonder whether the websites should first exist or not to allow Let’s Encrypt create the certificate.
I have not deployed my website yet, as they’re going to be containers, each one of them (still have to check nginx proxy to point to them).
Could that Let’s Encrypt error be due to the lack of the actual website contents?
DNS are defined automatically from hostinger.
So when adding a domain via HestiaCP, they’re already defined in Hostinger.
I followed the doc to add a domain, etc… but still, no ssl.
Well,
You nailed it. Thanks a lot. It now works without trouble.
The problem was the IP address.
The dig command did show another IP than my VPS.
I first tried a VPS with Hostinger in late June and then cancelled it while retaining my domains with them.
Now I’m back and have a new VPS, but the domains did all point to the former VPS IP.
Even a “reset default DNS values” still pointed to that old IP.
So I just changed all the A records from my domains to point to my current VPS IP and Let’s Encrypt now works. Of course since now it’s able to actually communicate with the real thing!
Shame on me , should have noticed that myself.
Thanks a lot.
