pluto
1
Just updated a server which upgraded nginx to 1.25.1
Warnings received on restart.
nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead
This will not break anything immediately, but just as a heads-up the old format is
server {
listen 90.91.45.3:443 ssl http2;
and the new format for nginx >= 1.25.1 is
server {
listen 90.91.45.3:443 ssl;
http2 on;
eris
2
Noticed yesterday as well probally modify all the default templates and check for nginx version during config generation…
floown
3
Hi @eris
So we should wait a futur Hestia update to fix the warn?
Regards
eris
5
Will get attention in the future… It currently should not affect any working setup. It is only anoying.
Will patch it in the future…
Updated title / pinned it because it has been asked to many times
