NGINX + Apache to NGINX Only Migration: Subdomain Routing Issue with PrestaShop and WordPress Directories
I reinstalled NGINX + Apache, switching to NGINX alone. It works much better. I have PrestaShop and WordPress websites on the server. Everything works great.
The problem occurs with one specific subdomain:
demo.site.com
There are many PS/WP pages in directories such as:
/wordpress_x/ (wordpress)
/wordpress_xxx/ (wordpress)
/cc_ps_prestashop_xx/ (prestashop)
/xxx/ (wordpress)
I created a new template that, depending on the directory, loads NGINX settings for Presta or WP. In short, directories for PS ALWAYS start with cc_ps, while all others are WP.
Unfortunately, it doesn’t work :frowning:
My .stpl template:
# Hybrid Demo Template - WordPress + PrestaShop                          #
server {
	listen      %ip%:%web_ssl_port% ssl;
	root        %sdocroot%;
	ssl_stapling        on;
	ssl_stapling_verify on;
	# TLS 1.3 0-RTT anti-replay
	location = /favicon.ico {
		log_not_found off;
		access_log off;
	location = /robots.txt {
		log_not_found off;
		access_log off;
		deny all;
		return 404;
	# PRESTASHOP RULES - dla katalogów zaczynających się od cc_ps
	# PrestaShop - Force pdf files to be downloaded
	location ~ ^/cc_ps.*\.pdf$ {
		add_header Content-Disposition Attachment;
		add_header X-Content-Type-Options nosniff;
	# PrestaShop - Force files in upload directory to be downloaded
	location ~ ^/cc_ps.*/upload/ {
		location ~ \.php$ {
			deny all;
			return 404;
	# PrestaShop - Images rewrite rules for cc_ps directories
	location ~ ^/cc_ps.*?/([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$1$2$3.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$1$2$3$4.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$1$2$3$4$5.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$4/$1$2$3$4$5$6.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/p/$1/$2/$3/$4/$5/$6/$7/$8/$1$2$3$4$5$6$7$8$9$10.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/c/([0-9]+)(-[.*_a-zA-Z0-9-]*)(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/c/$1$2$3.jpg /index.php?$args;
	location ~ ^/cc_ps.*?/c/([a-zA-Z_-]+)(-[0-9]+)?/.+\.jpg$ {
		try_files $uri /cc_ps/img/c/$1$2.jpg /index.php?$args;
	# PrestaShop - AlphaImageLoader for IE and fancybox
	location ~ ^/cc_ps.*?/images_ie/?([^/]+)\.(jpe?g|png|webp|gif)$ {
		try_files $uri /cc_ps/js/jquery/plugins/fancybox/images/$1.$2 /index.php?$args;
	# PrestaShop - Web service API
	location ~ ^/cc_ps.*?/api/?(.*)$ {
		try_files $uri /cc_ps/webservice/dispatcher.php?url=$1;
	# PrestaShop - Installation sandbox
	location ~ ^/cc_ps.*?(/install(?:-dev)?/sandbox)/(.*) {
		try_files $uri /cc_ps$1/test.php;
	# PrestaShop - Source code directories protection
	location ~ ^/cc_ps.*?/(app|bin|cache|classes|config|controllers|docs|localization|override|src|tests|tools|translations|travis-scripts|vendor|var)/ {
		deny all;
		return 404;
	# PrestaShop - vendor in modules directory
	location ~ ^/cc_ps.*?/modules/.*/vendor/ {
		deny all;
		return 404;
	# PrestaShop - Prevent exposing sensitive files
	location ~ ^/cc_ps.*?\.(yml|log|tpl|twig|sass)$ {
		deny all;
		return 404;
	# PrestaShop - img directory protection
	location ~ ^/cc_ps.*?/img/ {
		location ~ \.php$ {
			deny all;
			return 404;
	# PrestaShop directories - main handler
	location ~ ^/cc_ps {
			expires 30d;
		location ~ [^/]\.php(/|$) {
			try_files $fastcgi_script_name /index.php$uri&$args =404;
			fastcgi_index index.php;
			fastcgi_split_path_info ^(.+\.php)(/.+)$;
			fastcgi_pass %backend_lsnr%;
	# WORDPRESS RULES - dla wszystkich pozostałych katalogów
	location / {
			expires 30d;
		# WordPress - Block PHP in uploads/files directories
		location ~* /(?:uploads|files)/.*.php$ {
			deny all;
			return 404;
			try_files $uri =404;
			# WordPress cache rules
			if ($request_uri ~* "/wp-admin/|/wp-json/|wp-.*.php|xmlrpc.php|index.php|/store.*|/cart.*|/my-account.*|/checkout.*") {
				set $no_cache 1;
			if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in|woocommerce_items_in_cart|woocommerce_cart_hash|PHPSESSID") {
				set $no_cache 1;
	# COMMON RULES
	# Error pages
	error_page 403 /error/404.html;
	error_page 404 /index.php?controller=404;
	error_page 500 502 503 504 /error/50x.html;
	location /error/ {
	location /vstats/ {
	proxy_hide_header Upgrade;
Okay, I managed to solve the problem. I’m pasting the template here—maybe someone will find it useful :slight_smile:
server {
    root        %sdocroot%;
    ssl_stapling        on;
        log_not_found off;
        access_log off;
        try_files $uri $uri/ /index.php$is_args$args;
        log_not_found off;
        access_log off;
    location ~ /\.(?!well-known) {
        deny all;
    # PRESTASHOP RULES - Global rewrites (Official PS9 format)
    # Images
    rewrite ^/(cc_ps[^/]*)/(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$2$3.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$2$3$4.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$2$3$4$5.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$5/$2$3$4$5$6.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$5/$6/$2$3$4$5$6$7.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$5/$6/$7/$2$3$4$5$6$7$8.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$5/$6/$7/$8/$2$3$4$5$6$7$8$9.jpg last;
    rewrite ^/(cc_ps[^/]*)/(\d)(\d)(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /$1/img/p/$2/$3/$4/$5/$6/$7/$8/$9/$2$3$4$5$6$7$8$9$10.jpg last;
    rewrite ^/(cc_ps[^/]*)/c/([\w.-]+)/.+\.jpg$ /$1/img/c/$2.jpg last;
    # AlphaImageLoader for IE and FancyBox
    rewrite ^/(cc_ps[^/]*)/images_ie/?([^/]+)\.(gif|jpe?g|png)$ /$1/js/jquery/plugins/fancybox/images/$2.$3 last;
    # Web service API
    rewrite ^/(cc_ps[^/]*)/api/?(.*)$ /$1/webservice/dispatcher.php?url=$2 last;
    # Installation sandbox
    rewrite ^/(cc_ps[^/]*)/install(?:-dev)?/sandbox/(.*) /$1/install/sandbox/test.php last;
    # PRESTASHOP SPECIFIC LOCATIONS
    # PrestaShop admin directories
    location ~ ^/(cc_ps[^/]*)/admin[^/]*/ {
        try_files $uri $uri/ /$1/admin/index.php$is_args$args;
    # Source code directories
    location ~ ^/(cc_ps[^/]*)/(app|bin|cache|classes|config|controllers|docs|localization|override|src|tests|tools|translations|var|vendor)/ {
        deny all;
    # vendor in modules directory
    location ~ ^/(cc_ps[^/]*)/modules/.*/vendor/ {
        deny all;
    # Prevent exposing other sensitive files
    location ~ ^/(cc_ps[^/]*)/.*\.(log|tpl|twig|sass|yml)$ {
        deny all;
    # Prevent injection of PHP files
    location ~ ^/(cc_ps[^/]*)/img/ {
        location ~ \.php$ { deny all; }
    location ~ ^/(cc_ps[^/]*)/upload/ {
    # MAIN LOCATION HANDLERS
    # PrestaShop directories - exact copy of official PS9 config
    location ~ ^/(cc_ps[^/]*) {
        try_files $uri $uri/ /$1/index.php$is_args$args;
            expires 30d;
            # Official PrestaShop 9 PHP handler
            fastcgi_split_path_info ^(.+?\.php)(/.*)$;
            try_files $fastcgi_script_name =404;
            fastcgi_param SCRIPT_FILENAME $request_filename;
    # WORDPRESS CC_* DIRECTORIES (not cc_ps*)
    location ~ ^/(cc_(?!ps)[^/]*) {
        # WordPress official rule for subdirectory installations
        try_files $uri $uri/ /$1/index.php?$args;
            expires 30d;
        # WordPress - Block PHP in uploads/files directories (official security rule)
        location ~* /(?:uploads|files)/.*\.php$ {
            deny all;
        location ~ \.php$ {
            # WordPress cache rules (from official docs)
            if ($request_uri ~* "/wp-admin/|/xmlrpc.php|wp-.*.php|/feed/|index.php") {
                set $no_cache 1;
            if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in") {
                set $no_cache 1;
    # COMMON RULES
    location /error/ {
    location /vstats/ {
