Nginx can't start after updating HestiaCP
My HestiaCP just updated automatically to v1.9.2. Then my HestiaCP Admin can’t access because of error 500.
Then I run:
#sudo apt update && sudo apt upgrade
and
#apt install hestia --reinstall
Now my Nginx can’t start. It shows the error as attached image.
Please check for me!
Seems that nginx can’t start because apache2 is already running on those ports.
Not quite sure how that might have happened from an upgrade though.
Thanks!
I found the solution
Yes normally running apt update && apt upgrade apache2 asks to overwrite the default config files if you enter y it will overwrite them…
