Nginx failed to start and bind
Nginx cannot start because apache uses 80 port.
What should be in the conf files in Listen part? I think for nginx there should be just localhost. Am i right?
2022/10/13 11:02:02 [emerg] 9121#9121: bind() to xxx:8080 failed (98: Address already in use)
2022/10/13 11:02:02 [emerg] 9121#9121: still could not bind()
Probally you are using a template for Nginx as web but using Nginx + Apache2
Found solution. In my case all the nginx conf files where bind to 80 or 8084 ports except one - there was binding to 8080 port. It was generated from template for octobercms i just installed. I changed port to 8084 in conf file and problem has gone.
Probally you want to update the template you are using
from: web_port to proxy_port (And the stpl the same only web_port_ssl)
You are right. There is web_ssl_port and web_port in templates. Have to change them there. Will push PR on github.
Thank you!
