Nginx failed to start
I have multiple problems but i need this corrected asp please.
so when i ran the below code.
sudo nginx -t
this is what i got as the error.
[emerg] invalid number of arguments in “fastcgi_pass” directive in /etc/nginx/conf.d/domains/mydomainname.conf :37
so when i also did
sudo nginx -t -c /etc/nginx/conf.d/domains/mydomainname.conf
i got the following errors too.
[emerg] "server’’ directive is not allowed here in /etc/nginx/conf.d/domains/mydomainname.conf :7
I will be glad if i get some assistance please. Thank you
contents of /etc/nginx/conf.d/domains/mydomainname.conf
Thanks for your support but i do not understand what i am suppose to do. So please i will be glad if you can explain further with details so it will be easier to resolve my issue
I would try to rebuild the web for that user, by using the command
v-rebuild-web-domain
Always make & test backups before doing so.
thanks man this really works
