Is it supported http2.0 in nginx and how to enable for all users?
You didn’t say what is the Hestia version you are using but in last releases, HTTP2 is enabled by default.
grep -RE '^http2' /etc/nginx/
Using curl to access the https version of your domain, you should see something like this:
$ curl -IkL https://yourdomain.tld
HTTP/2 200
server: nginx
And you should see it is using HTTP/2.
It is already enabled by default…
If I am not wrong http2 was removed in
[Feature] TLS 1.3 0-RTT with replay protection by myrevery · Pull Request #3692 · hestiacp/hestiacp · GitHub .
Edit: This is implemented in Resolve #3684 Process "http2" directive for NGINX by myrevery · Pull Request #3704 · hestiacp/hestiacp · GitHub .
